white clipping in EVF
hallo leute, sorry ich poste in englisch, ihr koennt aber auch in deutsch antworten falls euch danach ist.. mir faellt englisch einfacher.
I got my x100 and there's some issues which make me feel very uncomfortable!
for the first.
whenever I set my camera to macro mode or burst shoot or depth of field preview and I do one photo all settings reset?
so I have to set them again for every photo? - how is this supposed to work in street photography where you have to handle quick?
for the second part - manual focusing is shit (it works in depth of field preview mode better) but then again it resets after each photo - how is that supposed to work for street photographers? (basically all my photos even when using the quick autofocus button and refocusing afterwards - where out of focus).
for the third part - there's no menu entry to set the camera to stay on burst or continuous shooting in the menu - how is this supposed to work for street photographers.
for the fourth - whenever I make a photo which is either overexposed or has direct sunlight - right after doing the photo I see the photo in the electronic viewfinder but the highlights are clipping like hell.. when I then switch to the back lcd the highlights are fine.. is this a bug? - how is this supposed to work for street photography when you have to review quickly.
seems that all the posts I have read sofar are from complete amateurs.. because In a professional way there are a lot of issues.
aswell as a lot of missing menu entries for setting up the camera proberly.
for any suggestions I will be delighted.
Maybe should I send a bug report to fuji or send back the camera for the clipping problem, can someone confirm the problem aswell?
thank you
Bastian
You may be more successful in making yourself understood if you would use your native language. Just a suggestion …
I’m wondering whether you are still using firmware version 1.00 or 1.01. The new version (1.10) should solve the issue you have with the drive mode and other settings failing to stick when switching modes.
Btw I think that in your apparent contempt for amateurs you are missing the fact that the X100 is a camera squarely aimed at the amateur market. And of course being an amateur or a pro says nothing about a photographer’s talent or their ability to appraise both the positive and the negative aspects of a camera they own.
ok, damn, sorry Ich lebe seit langer zeit im ausland und mir faellt es einfacher mich mit der taeglichen sprache zu artikulieren, aber ich stimme zu die muttersprache sollte eigentlich am einfachsten sein.
nachdem ich mich hier gerade schoen durchlese lerne ich viele gute tricks, ..das forum gefaellt mir sehr und die fotografen scheinen ihr handwerk zu verstehen!
natuerlich ist die kamera nur ein tool, fuer mich ist jedoch geschwindigkeit ausschlaggebend - aber wahrscheinlich einfach etwas gewoehnung mit der kamera.
ich hab noch die alte firmware drauf, danke fuer die info, werde alsbald updaten.
ich habe eher gelesen dass die x100 im semipro segment als zweitkamera gedacht ist. und fuer street/ reportage ist sie ja gut geeignet. Sogar fuer war-photografie haette ich sie mir gut vorgestellt, eine leica m8 ist ja noch erschwinglich aber im kugelhagel mit einer leica m9, naja.. (nicht das ich sowas mache) aber bei einem body fuer 1k waere mir das dann nicht so schwer im magen wenn der kaputt geht.
eigentlich sind alle meine fragen beantwortet, bis auf das clipping, ..kann das jemand bestaetigen - ich moechte nur sichergehen dass ich keinen bug in der software habe.
also nochmal auf deutsch: wenn ich durchs kuckloch schaue und den evf aktiviert habe auch wenn perfekt belichtet ist sind die weissbereiche stark gedrueckt, wie als entwickle man einen film aus den sechzigern. (alle menu settings auf default).
gibts da ein eigenes helligkeits menu fuer den glotzboebbel? weil im lcd display passt das geschossene bild wunderbar.
danke.
Die Vorschau unmittelbar nach der Aufnahme zeigt das Ergebnis einer vorläufigen Bildverarbeitung und stimmt nicht genau mit dem Bild überein, das tatsächlich gespeichert wird und das man angezeigt bekommt, wenn man in den Wiedergabemodus wechselt. Man kann die Vorschau nutzen, um schnell zu prüfen, ob man den entscheidenden Moment erwischt hat, aber wenn man die Bildqualität ernsthaft beurteilen will, sollte man den Wiedergabemodus nutzen.
Archived
