Trulla Posted June 17, 2022 Share #1 Posted June 17, 2022 Werbung (verschwindet nach Registrierung) Kann mir jemand in ein paar kurzen Sätzen erläutern, was an der xt-30ii gegenüber der xt-30 verbessert wurde? Lohnt sich der Aufpreis von 200,-€ ? Quote Link to post Share on other sites More sharing options...
Advertisement Posted June 17, 2022 Posted June 17, 2022 Hi Trulla, Take a look here xt-30 vs. xt-30ii. I'm sure you'll find what you were looking for!
T. B. Posted June 17, 2022 Share #2 Posted June 17, 2022 Durch geänderte Hardware verbesserter AF, Klappdisplay mit höherer Auflösung, etwas mehr Serienbilder in Folge möglich. Und die C1-C7 Speicherungen wurden erweitert auf den Umfang wie bei der X-E4. Mehr fällt mir gerade nicht ein. Trulla 1 Quote Link to post Share on other sites More sharing options...
Sushirunner Posted June 18, 2022 Share #3 Posted June 18, 2022 (edited) Hier gibt's einen guten Vergleich https://mirrorlesscomparison.com/fujifilm-vs-fujifilm/xt30-vs-xt30-ii/ Ergänzung zu oben: The X-T30 II has two additional film simulation modes (picture colour profiles): Classic Neg and Eterna Bleach Bypass. Along with the extra image profiles, the X-T30 II inherits extra settings you won’t find on the original model. These are: Clarity Tone Curve with 1/2 step adjustment (called highlights and shadows on the X-T30 but with 1 step adjustment) White Priority and Ambience Priority for the Auto White Balance Monochromatic Color with the freedom to give the image any colour tone you want (on the original X-T30, it’s cooler or warmer only) Colour Chrome FX Blue which makes blue colour deeper The X-T30 II has a limitation of 30 minutes per clip in 4K, which is a good step forward from the 10min cap on the X-T30. Then, we have the High Speed mode for the production of slow motion videos. The mark II model can record up to 240fps, whereas the X-T30 stops at 120fps. The quality should be exactly the same as the X-T4. Edited June 18, 2022 by Sushirunner Trulla 1 Quote Link to post Share on other sites More sharing options...
