Taloan Geschrieben 30. Mai Share #1 Geschrieben 30. Mai Werbung (verschwindet nach Registrierung) Version: 3.20 Last Updated: 29.05.2025 https://www.fujifilm-x.com/de-de/support/download/firmware/cameras/x-s20/ Detail of the firmware update Ver.3.20 The firmware update Ver.3.20 from Ver.3.10 incorporates the following issues: Regarding the details of No.2, download the “X-S20 New Features Guide[Ver.3.20]” from our website. ・X-S20 New Features Guide: English, Français, Deutsch, Español, Italiano, Nederland, Polski, Svenska, Norsk, Dansk, Pусский, Suomi, 中文简, 中文繁體, 한국어, ภาษาไทย, Arabic Exposure tracking during aperture movement gets smoothed when used with the XF16-55mmF2.8 R LM WR II. The above exposure tracking function is enabled under the following setting conditions. [Setting conditions] ・StillMovie mode ➔ Movie ・Shooting Mode ➔ Manual (M) Mode ・ISO ➔ Fixed Sensitivity The “LINEAR” setting in “Focus ring operation” menu can now be set by the focus ring rotating angle. The above function is enabled when used with the following applicable lenses. [Applicable lenses] ・XF/XC series Prime lenses and zoom lenses Note:Interchangeable lenses with distance indicators (XF14mmF2.8 R, XF23mmF1.4 R and XF16mmF1.4 R WR) are not applicable. A firmware bug is fixed that the image display becomes abnormal in rare cases for the images processed by RAW development from the RAW files shot with the following bracketing function. [Bracketing function] ・ISO BKT ・FILM SIMULATION BKT ・WHITE BALANCE BKT A firmware bug is fixed that the camera does not turn on even if the power lever is on when a specific SD memory card is inserted. A firmware bug is fixed that the “WRITE ERROR” occurs in rare cases after shooting when using specific SD memory cards. Link zum Beitrag Auf anderen Seiten teilen More sharing options...
Anzeige Geschrieben 30. Mai Geschrieben 30. Mai Hallo Taloan, schau mal hier X-S20 Firmware update 3.20 . Dort wird jeder fündig!
Taloan Geschrieben 30. Mai Autor Share #2 Geschrieben 30. Mai Gerade per App erfolgreich aktualisiert 👍 Link zum Beitrag Auf anderen Seiten teilen More sharing options...
aljosa Geschrieben 9. Juni Share #3 Geschrieben 9. Juni Unter dem Link ist die FWUP0032.DAT nicht mehr vorhanden, nur noch die FWUP0031.DAT. Hat jemand eine Idee wo ich das aktuelle Update jetzt finde? Vielen Dank. Link zum Beitrag Auf anderen Seiten teilen More sharing options...
lowrider82 Geschrieben 9. Juni Share #4 Geschrieben 9. Juni vor 26 Minuten schrieb aljosa: FWUP0032.DAT vor 26 Minuten schrieb aljosa: FWUP0031.DAT Der Dateiname bleibt pro Modell gleich. Egal welche Version. Die Zahl darin hat NICHTS mit dem dem Versionsstand zu tun. Die Version siehst du erst, wenn du mit halten von Disp/Back die Kamera einschaltest. Und beim Download darauf achten, daß durch eine gleichlautende Datei kein (1) angefügt wird. Einen abgeänderten Dateinamen erkennt der Updateprozess nicht. aljosa und fujirai haben darauf reagiert 2 Link zum Beitrag Auf anderen Seiten teilen More sharing options...
fujirai Geschrieben 9. Juni Share #5 Geschrieben 9. Juni vor 3 Stunden schrieb aljosa: nur noch die FWUP0031.DAT. Hat jemand eine Idee wo ich das aktuelle Update jetzt finde? Die 0031 ist die aktuelle. 0032 Wäre für eine andere Kamera, und es hat "32" auch nichts mit "3.20" zu tun. aljosa hat darauf reagiert 1 Link zum Beitrag Auf anderen Seiten teilen More sharing options...
aljosa Geschrieben 10. Juni Share #6 Geschrieben 10. Juni (bearbeitet) Am 9.6.2025 um 07:13 schrieb lowrider82: vor 21 Stunden schrieb fujirai: Vielen Dank euch Beiden. bearbeitet 10. Juni von aljosa lowrider82 und fujirai haben darauf reagiert 2 Link zum Beitrag Auf anderen Seiten teilen More sharing options...
