Hello!
My camera seems to be stuck in MF mode.
I've trawled the internet and searched forums and cannot find a solution.
Tested with both the Fujinon XF 27mm & the 18-55 lenses and nothing. Maybe I've f**cked up some settings somewhere? I tried reseting and it still nothing.
The AF mode is greyed out however it does AF when use back button focussing? AND i've noticed it says "mount adaptor setting' now within the settings which i don't remember seeing before...
Any wizards out there who can help?
Chris
-- Current settings:
AF Mode - greyed out
AF corrected AF frame - OFF
Mount adaptor setting - 50mm
Shoot without lens - off
AE/AF lock - on when pressing
AE/AF lock button - A/E lock
Autorotate - ON
MF assist - peak
AF + MF - off
Hi Chris.
The connectors at the lens mount are clear of materials that din´t belong to this point.?
Clear with soft alcohol and something witch is lint-free. Perhaps electrical connection is bad. The lenses needs electrical power and the signals to do right what the cam says.
schorschi
