X100S oder besser doch X100T
Frankny212
Forenexperten behaupten oft, dass es zwischen der X100S und X100T kaum Unterschiede gäbe. Bis die wenigen folgenden Kleinigkeiten stimmt das auch:
  • A clean user interface on the inside and outside that doesn’t interfere with your composition, yet displays a plethora of information
  • EVF info display adapts to horizontal or upright camera holding position (sadly, the LCD interface doesn’t change)
  • Quick and easy image review using the focus ring as a control ring to browse through images when zoomed in
  • Aperture ring with 1/3 stop clicks
  • Larger ± 3 EV exposure compensation (EC) dial with more torque
  • Exposure compensation works in manual exposure mode (when Auto-ISO is active)
  • 3 different configurable Auto-ISO settings to choose from
  • “Thumb-wheel”-style command dial à la X-E2
  • Direct AF frame positioning option using the 4 selector buttons
  • 7 customizable Fn buttons, with many functions now working as quick toggles
  • Customizable Quick menu with 16 slots
  • Face detection with auto fall-back to any user-selected AF frame
  • Option to link the spot metering area to the active AF frame (position and size)
  • Seamlessly integrated electronic shutter with 1/32000s maximum shutter speed
  • Larger 3:2 LCD display with improved resolution (sadly, it’s not tiltable)
  • Improved EVF with minimized display lag (realtime view) and much better low light performance (frame rate)
  • Almost perfect WYSIWYG, including auto brightness in the electronic viewfinder (EVF) and full dynamic range (DR) mode simulation in the live view and live histogram
  • Natural Live View option drastically increases the dynamic range of the EVF or LCD screen and is quite helpful when composing a high-contrast scene in bright light
  • Improved optical viewfinder (OVF) with innovative electronic range finder (ERF) feature and real-time parallax correction
  • Good autofocus performance, including object tracking features à la X-T1
  • Improved multi-point AF-S mode
  • Instant-AF supports phase detection autofocus (PDAF)
  • Classic Chrome
  • Much larger and hence more robust JPEGs
  • Wifi with remote control for iOS and Android devices; direct Instax printing
  • Electronic shutter release with RR-90 (micro USB) or the microphone input
  • Built-in intervalometer
  • Improved video mode with additional frame rates, full manual control (aperture, shutter speed, ISO) and film simulation support (sadly, no support for the DR function)
  • In-camera USB charging
  • More reliable battery level indicator
Ich wusste ich hatte den einen oder anderen Punkt vergessen :D
  • Antworten 69
Selbst die Gesichtserkennung ist, auch wenn 23mm nicht gerade die klassische Portrait-Brennweite ist, sehr nützlich wenn man die Kamera für das Urlaubsfoto mal einem anderen in die Hand drücken will!
Jetzt hat die X100s noch immer keine Gesichtserkennung?!
Ich verstehe die Updatepolitik von Fuji nicht !
Wieviele Hersteller kennst du denn, die ihre Kompaktkameras regelmäßig mit Verbesserungen versorgen? Die X100 hat letztes Jahr noch ein Firmwareupdate bekommen.
Die Konkurenten wären beispielsweise Nikon, Sigma, Ricoh und Leica.
Die Konkurenten Nikon Coolpix A, Sigma DP2 M, Ricoh GR und Leica X2 brauchen kein Firmwareudate, da sie bereits mit einer Gesichtserkennungsfunktion ausgestattet sind ;)
Olympus hat also bei älteren Kompaktkameras mit Festbrennweite die Gesichtserkennung nachgerüstet? Respekt.
Olympus hatte bereits bei der allerersten spiegellosen Systemkamera der E-P1 im Jahre 2009 eine gut funktionierende Gesichtserkennung dabei ;)
Fujifilm hat dem aktuellem Modell Eine spendiert.
Finde ich Super !
Ist bei der Sigma freilich glatt gelogen. Dir steht es natürlich frei eine X100t oder eine der oben genannten Kameras zu kaufen und sich über die nicht bessere Updatepolitik zu wundern :)
Mich als Lügner dazustellen braucht es nicht, daher klinke ich mich hier jetzt aus  :)
http://www.photoscala.de/Artikel/Firmware-v103-v104-fuer-Sigma-DP1-DP2-Merrill
Inhalt: Sigma hat für die Kompaktkameras DP1 Merrill und DP2 Merrill je eine neue Firmware in Version 1.03 respektive 1.04 online gestellt, mit der die Kameras u. a. die Gesichtserkennung und RAW-Schwarzweißaufnahmen beigebracht bekommen
Du hast ja behauptet, dass Sigma kein Firmwareumdate braucht, da sie mit einer Gesichtserkennung ausgestattet sei. Dann brauchte sie wohl doch ein Update :)
Ich habe es so verstanden, das bei der leica MM gar keine Bayer pattern über dem Sensor liegt. Das ist das besondere an ihr. Bei der Sigma scheint ja "nur" die rohdatenerfassung verändert worden zu sein. Mich würde da interessieren was genau passiert? Ich glaube nicht das die farbpixel auf einmal "verschwinden" wenn man raw-Schwarzweiß auswählt
Inhalt: Sigma hat für die Kompaktkameras [/size]DP1 Merrill und [/size]DP2 Merrill je eine neue Firmware in Version 1.03 respektive 1.04 online gestellt, mit der die Kameras u. a. die Gesichtserkennung und RAW-Schwarzweißaufnahmen beigebracht bekommen[/size]
Meine Frage bezog sich doch auf das Update der Sigma...
Auch ich bin (beruflich) z.T. mit sehr großer Ausrüstung unterwegs, aber die "100" ist meine Lieblingsknipse. Einst war die (schon sehr gute) Ur-Version meine ständige Begleiterin, heute ist es die "T". Der würde ich gegenüber der "S" klar den Vorzug geben...
 Ich habe sie, in schwarz :D. Denke das dass kein Fehlkauf war. Für meine kleine Problemchen betreffend Operative Sprunggelenksversteifung und Knieprobleme, wo ich schon merke wenn ich zuviel mit mir herumtrage, ist sie ideal. Man spürt sie kaum in der Tasche. Und fürs Fahrrad passt sie sehr gut in eine Hüft/Bauchtasche. Bestellt habe ich mir jetzt noch von JJC die kleine Gegenlichblende.
Jetzt wäre nur noch eine neue Tasche fällig, meine hat schon deutliche Gebrauchsspuren, abgewetzt ect.
Gruß, Manfred
Gast mainhattaner
Na dann viel Spaß damit @Manfred, und schwarz passt auch. Natürlich Geschmackssache, aber ich würde mir nie eine (auffällige) silberne Knipse umhängen. Vielleicht radeln wir ja mal aneinander am Mainufer in der City vorbei. Ich bin der Typ mit dem gelben Faltrad  :)
Viel Spaß mit der Kleinen in schwarz, Manfred.
Für mich kommt eine Kamera ohne Gesichterkennung nicht mehr in Frage!
Prima. Schön, dass uns niemand zwingen kann, etwas zu kaufen, das wir überhaupt nicht haben wollen, :). Noch schöner, dass irgendwer, das anbietet, was wir meinen, unbedingt haben zu müssen, ;). So lässt es sich leben, gell?
Eine Frage an die Besitzer einer X100-S-T:
Ich habe gestern die Kamera (X100T) im Laden befingern und wurde nicht schlau über die Dualität Optischer-Elektronischer Sucher. Wechselt das „Guckloch“ vom Optischen zum Elektronischen? Ist der Hebel vorne, neben dem Objektiv, für den Wechsel zuständig? Die Kamera hatte keine Batterie und die Auszubildende wäre mit meiner Frage überfordert … Ich frage, weil ich „nur“ eine E-X2 besitze. Besonders für Städtereise wünsche ich mir, dass die Kamera, ähnlich wie bei meinen DSRLs, die ganze Zeit eingeschaltet bleibt, so dass ich den elektronischen Sucher nicht laufen lassen muss. Die Vorteile des elektronischen Suchers sind mir klar und wichtig, aber gerade bei Street, wenn ich die Kamera jedes Mal einschalten und warten muss bis der Augensensor mein Auge hinter der Brille erkennt, dann ist das Motiv weg. Wäre eine X100-S-T was für mein Problem? Es tut mir leid, dass ich so eine dilettantische Frage stellen muss, ich kenne mich nur mit der E-X2 aus und hatte keine Zeit mich zu belesen … Besten Dank Gilberto
Vielen dank für die schnelle Antwort, taby. Noch 2 Fragen und dann lasse ich euch in Ruhe damit. 1. Wie ist das mit dem Energieverbrauch wenn ich nach drsl-manier die Kamera in ständige Bereitschaft bei einer tagestour trage und nur mit dem optischen sucher arbeite, bringt das was? Macht das jemand? 2. Ich vermisse bei meiner e2 eine umschalttaste zwischen Display und sucher. Ich habe bei manchen touren versucht ganz auf das Display zu verzichten, aber dann kommt ein Motiv, wo ich das Display doch lieber nutzen würde. Dann muss ich wieder ins das Menü gehen um ihn zu aktivieren. Hat die x100 Serie eine umschalttaste Display-Sucher?
