... gibs dann zB. hier zu Lesen mit Videos: https://www.fujirumors.com/fujifilm-firmware-updates-for-x-h2s-improved-subject-detection-and-tracking-x-h2-ft-xh-file-transmitter-grip-and-xc15-45/
Firmware X-H2 1.20  >>https://fujifilm-x.com/global/support/download/firmware/cameras/x-h2/
Firmware X-H2s 3.00 >>https://fujifilm-x.com/global/support/download/firmware/cameras/x-h2s/
Detail of the firmware update
Ver.3.00
Revised specification from Ver.2.10 to Ver.3.00
Refer to the “X-H2S New Feature Guide” and “X-H2S Network and USB Setting” for the following items No.3, No.5 and No.6 that will be added and revised with new firmware (See the following links).
New Features Guide: English, Français, Deutch, Español, Italiano, Nederland, Polski, Svenska, Norsk, Dansk, Pусский, Suomi, 中文简, 中文繁體, 한국어, ภาษาไทย, Arabic
X-H2S Network and USB Setting: English, Français, Deutch, Español, Italiano, Nederland, Polski, Svenska, Norsk, Dansk, Pусский, Suomi, 中文简, 中文繁體, 한국어, ภาษาไทย, Arabic
Subject detection enhancement by AI (Artificial Intelligence).
(1)Current subject detection function improvement
Subject detection performance has been greatly improved in situations that were difficult to detect with the current firmware, such as “backlighting”, “looking sideways”, and “small subjects”. The subject detection function can be used more than ever, regardless of the scene.
(2)New subject category added
“Insect” and “Drone” detection is newly realized In addition to the existing “Face”, “Eyes”, “Animal”, “Bird”, “Automobile”, Motorcycle & Bike”, “Airplane” and “Train”. Insects can be detected by setting the subject as “Bird” and drones can be done by setting it as “Airplane”.
Dynamic tracking performance enhancement by the improved AF algorithm.
(1)The motion prediction algorithm has been improved to enable stable tracking of subjects moving at high speed in the frame.
(2)The AF focusing speed has been improved when continuous shooting is started by simultaneously pressing the AF-ON button and the release button while the camera is out of focus. The AF starts to focus at a faster rate than before, even in situations where the situation changes moment by moment, such as in sports. This makes it difficult to miss a shutter release opportunity, even in situations such as sports where the situation changes from moment to moment.
Tripod grip, “TG-BT1” has been available.
When the camera and “TG-BT1” are connected via Bluetooth, you can shoot still images and movies while holding the grip, as well as zoom in on lenses (*1) with an electric zoom function.
*1:Lenses with an electric zoom function (“Power Zoom Lens”)
・FUJINON LENS XF18-120mmF4 LM PZ WR (Ver.1.00 or later)
・FUJINON LENS XC15-45mmF3.5-5.6 OIS PZ (Ver.1.10or later)
Note-1:
For the “TG-BT1” initial settings and operating instructions, please download the “Tripod Grip (TG-BT1) User’s Manual” from our website (See the link below).
Note-2:
Firmware update for the camera and lens is required to enable this function.Make sure to update the camera firmware to the latest firmware before updating the lens firmware.
FUJINON LENS XC15-45mmF3.5-5.6 OIS PZ Firmware update Ver.1.10
File Transmitter (FT-XH) performance enhancement.
The live view frame rate from camera to terminal has been Improved when connecting the “FT-XH”.
Note-1:
Firmware update for the camera and “FT-XH” is required to enable this function.Make sure to update the camera firmware to the latest firmware before updating the “FT-XH” firmware.
”FT-XH” Firmware update Ver.1.10
Menu title change.
(1)”IMAGE TRANSFER ORDER” has been renamed to “COMMUNICATION STATUS”, which appeared through the following operation flow.
 ・[SCREEN SET-UP] ➔ [DISP. CUSTOM SETTING] ➔ [COMMUNICATION STATUS]
(2)“COMMUNICATION STATUS” can now be used to toggle the image transfer order and connected device displays on or off simultaneously.
“Bluetooth DEVICE LIST” addition.
“Bluetooth DEVICE LIST” has been added in the “Bluetooth/SMARTPHONE SETTING” in the “NETWORK/USB SETTING” menu.
Bug fixes.
(1)Firmware bug has been fixed, which caused the freezing that occurs before and after AF is performed.
(2)Other minor bugs have been fixed.
bearbeitet von der_molch
richtig klasse! So wie ich vermutet habe, wird bei der X-H2S eben das eine oder andere große Update kommen, da enormes Potential drin steckt. Die X-H2 wird in nachgelagerten Schritte sicher auch profitieren.
Allerdings werde ich erst nach der standesamtlichen Hochzeit heute die Aktualisierung anstoßen. Im Moment weiß ich was die Kamera macht, da kommt mir ein kompletter Versionssprung kurz vorher eher ungelegen 😉
vor 20 Minuten schrieb A.B.:
hast Recht, erstmal heiraten... ist wichtiger...
vor 43 Minuten schrieb Batzman:
Interessant. Die X-H2S ist nach so kurzer Zeit schon bei V3.0. Bei meiner X-T4 stehe ich gerade bei der aktuellen Verison 1.70.
Dafür hat die X-T4 aber schon den 14. Firmwarestand seit ihrer Einführung ;) !
Ist halt davon abhängig, wie die verschiedenen Stände benamt werden.
Bei der X-H2s ist es erst der 5. Firmwarestand 😁
bearbeitet von Allradflokati
Gast
